help!!!
Old Aug 4, 2002 | 11:12 PM
VTtransam's Avatar
Default help!!!
ok here goes, a few weeks ago i installed a '02 z06 clutch assembly and updated hydrolics on my 99 ta. Right after the install i started getting a creaking noise when the tranny was under load (starting out or accelerating). I replaced my tranny mount today to an engergy suspension mount. It stoped creaking when i start out, but i have alot of vibration when accelerating and when the clutch is disengaged at a stop light, it makes a small creaking noise. I have no idea what's wrong and i'm gettin frustrated, any help would be greatly appriciated. Thanks!!!!!!!!
Old Aug 6, 2002 | 10:48 AM
Ragtop 99's Avatar
Default Re: help!!!
ttt
Old Aug 6, 2002 | 11:11 AM
Fireball's Avatar
Default Re: help!!!
as far as the vibration...did you put the shim in with the tranny mount? try removing the shim...it seems to be a source of vibration. Also remember that it will transmit some more vibration than stock rubber mounts
Can you elaborate more on the "creaking" noise?
Old Aug 7, 2002 | 08:27 PM
VTtransam's Avatar
Default Re: help!!!
Thanks guys, I got it straitened out today!!
