Torque Specifications
Pretty sure the torque specs are the same for the TA and the TAhoe.
http://www.texasfbody.org/TorqueSpecs/#4L60E
Flywheel to Torque Converter Bolt 46 lb ft
Transmission to Engine Bolt 35 lb ft
Only bolts I loc-tited are the Torque Converter bolts, which you also need to make sure are grade 8 if they didn't come with the converter.
Wouldn't want cheap bolts, or to come loose on something that's spinning @ 6000 RPM...
