output shaft question??
Old Dec 19, 2006 | 07:18 PM
smask04C5's Avatar
Default output shaft question??
Is the slip yoke different between a threaded and non-threaded output shaft on a turbo 400 or the 4L80?
Old Dec 19, 2006 | 08:36 PM
FLT's Avatar
FLT
Yes because the yoke for the bolt on style is going to have a large hole in it for the bolt. Also the bolt in style yoke is shorter I believe.
Old Dec 20, 2006 | 05:18 AM
smask04C5's Avatar
Thanks for the info Vince. I messed up the driveshaft order. I used a 4L80 output shaft and it does have the bolt hole. I will find out if CF driveshaft can provide a counterbored yoke.
