M6 to Auto guys in here please
Old Dec 21, 2006 | 12:31 PM
code4's Avatar
Default M6 to Auto guys in here please
Going thru a th400 install right now. What did you guys do with your clutch pedal? Should I try to get an auto brake pedal? I could just wack the clutch off with a sawzall but I wonder if having such a small brake pedal is a bad thing?
Old Dec 21, 2006 | 01:06 PM
blkbird_WS-6's Avatar
Some guys like to pull the clutch pedal out and put the auto brake pedal in. I personally left my clutch pedal in the car, it doesn't do anything, hell I still have the clutch master cylinder in the car. The pedal will not move once the line is disconnected from the slave. Just tap into the lower clutch switch and run wire from there to the park/neutral switch on the shifter for the auto, and you should be good to go.
Old Dec 21, 2006 | 07:07 PM
code4's Avatar
Yep I wired up the park/neutral switch. Having 2nd thoughts about leaving the pedal.
Old Dec 21, 2006 | 09:10 PM
SLowETz's Avatar
Left mine on the floor as well.
Old Dec 22, 2006 | 01:45 AM
93_z28's Avatar
can you still use a stock driveline with a th400?
Old Dec 22, 2006 | 09:18 AM
code4's Avatar
No, it takes a longer driveline.
Old Dec 22, 2006 | 12:18 PM
I just ordered a whole new driveshaft thru Spohn and it fits fine. It's definitely longer than the stock piece.
Old Dec 22, 2006 | 12:30 PM
ss1129's Avatar
I bought a used brake pedal/ bracket assembly from someone on these boards for like $40.00. I felt it would be ghetto to leave the manual setup in there.
Old Dec 22, 2006 | 04:14 PM
BTLFEDSS's Avatar
Me too
BTLFEDSS
Old Dec 22, 2006 | 05:16 PM
code4's Avatar
I'm thinking I will change mine out as well, was it a **** to do?
Old Dec 22, 2006 | 11:12 PM
LPTXZ28's Avatar
it is a pain to get the three pedal assy. out but the auto pedals are a breeeze.
Old Dec 22, 2006 | 11:25 PM
code4's Avatar
I have it out, it wasn't too bad.
