th350/400 guys
Old Dec 29, 2006 | 02:21 PM
RICEETER's Avatar
Default th350/400 guys
you may have seen me posting in the th350/400 AND in the built 4L60E threads; thats because im undecided on which im gonna settle with. anyway my question is: i've notice that the th350/400 converters have straight thru mounting holes rather than tapped out like my yank. so what bolts/nuts are you all using to mount the converter to the flexplate and where are y'all getting them?
also, where can i find the speed sensor and rotor? and how do i go about mounting it?
thanks,
brent
Old Dec 30, 2006 | 10:56 AM
NEVR2ND's Avatar
Depends on where you buy the converter from. My converter has tapped out holes.
I purchased my speed sensor from E-Bay for $20 and the rotor(reluctor ring), from GM Parts direct. I think the PN are 8655291 for the sensor and 8655315 for the rotor. Just double check on the numbers.
Old Dec 30, 2006 | 03:31 PM
DanZ28's Avatar
You also need the right tail shaft to adopt the SS right?
I have a Neal Chance TC and it came with threaded holes. It used some big bolts like 7/16-20 threads I believe.
Dan
Old Dec 30, 2006 | 05:04 PM
BTLFEDSS's Avatar
My PTC came with tapped holes
BTLFEDSS
