tranny pump??
Old Dec 29, 2006 | 07:10 PM
95FbFormula's Avatar
Default tranny problem??
I just finished pulling my motor today after my car has been sitting since october. When i went to pull my converter off and let it drain it only trickled out a little bit of fluid maybe 1/4 of a quart. does this seem like a problem or was it just because it has not be stated since october and i did lose fluid when removing the cooler lines and the dip stick.
Sry for got to add this is a 4l60-e
Old Dec 29, 2006 | 07:41 PM
performabuilt's Avatar
LS1Tech Sponsor
Over time fluild would drain from the converter into the trans with the car setting that long , So probably not a problem if the car has not been started since october
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 30, 2006 | 08:56 AM
Gilbert@Ace Racing's Avatar
There is not much to worry about given that the car has sat for a month or two. It is perfectly normal for torque converters to drain fluid back into the transmission... especially ones that do not have anti-drain back check valves /***** in the hydraulic circuitry.
g
