Trans guys step inside
Old Jan 5, 2007 | 09:03 PM
mdacton's Avatar
Default Need some trans help
Building another th350
I want this one to be a lo drag trans for a bracket car...foot brake only
What clutches do you rec.? I currently have a set of raybestos Got everything local they said its the best stuff they have
What direct clutch drum bushing do you rec.? and where to find it
Aftermarket sprag and drum...I'm not will to put out 900 bucks for an aluminum on, so where do you rec. getting the best steel one
How do you feel about using a lower bypass spring on the pump , to run 85-110psi line press.? to reduce parasidic loss
whitch clutch plates etc. can be eliminated to reduce rotating weight?
I will be running a SCS cheetah manual forward valve body, I also allready have my converter 9" 4500
Plan on replacing all the bushings as well
__________________
