bolts for pilot spacer
Old Jan 12, 2007 | 12:51 PM
Darracq's Avatar
Default bolts for pilot spacer
can i use stock flexplate bolts or do i need longer ones becasue of the spacer.
Old Jan 12, 2007 | 10:46 PM
jay_lt4's Avatar
depends which spacer you are using,,
the hughes spacer is a press/tap fit into the rear of the crankshaft(can only be used with a curved flex plate(5.3,LS1))
the gm 6.0 spacer uses longer bolts and if you have the flat 6.0 flexplate the spacer goes on first then the flexplate then bolts,, if you use the curved flexplate the flexplate goes on first then the spacer then bolts
Old Jan 13, 2007 | 10:32 AM
Darracq's Avatar
I used the GM spacer, stock 2000 or 01 flexplate. put flexplate then spacer then stock bolts, Hughes said to make sure the converter is all the way in, i am pretty sure it was though.
Old Apr 28, 2007 | 04:29 PM
yobabiesdaddy2001's Avatar
can you remove the spacer?
