trans stuck to motor
Old Jan 14, 2007 | 02:18 PM
snakesmash'nLS1's Avatar
Default trans stuck to motor
Any one have any helpful hints on how to break my trans off the motor I have been fighting with this thing all day.
Old Jan 14, 2007 | 02:21 PM
LS1x2's Avatar
Formerly 4mulaJoe
Isn't there a little gap where you can put a thick flathead in there? Just do that and pry it a bit.
Old Jan 14, 2007 | 02:22 PM
The1N_only's Avatar
Make sure you have all 7 bell housing bolts off, Your torque converter unbolted, spray some PB blaster on the dowels and get pry bar on each side and it should come off.
I tried but its starting to get a wee bit buggered up I thinking about making a wooden wedge and seeing if that works
Old Jan 14, 2007 | 02:26 PM
Mssingkid's Avatar
I had the same issue when i went to remove my 4L60E. Seems the Dowel pins were seized to the tranny. I borrowed some little metal wedges from a friend. Slid one in, then another and another till i had all three in on the bottom. Once i had about an inch worth of clearance i used a crow bar to force them apart. Within an hour i had them separated, and wouldn't you know the damn trans took the dowel pins out of my block!! No damage to the block luckily.
Old Jan 14, 2007 | 02:55 PM
DROPTOPLS1's Avatar
PB blaster on the dowels and put anti seize on them when you put it back together to make it easier for next time.
Old Jan 14, 2007 | 04:16 PM
Well got one dowel loose but that other is not going to give in. I will have to jump back on it after work tomorrow. Thanks for the tips!
Old Jan 14, 2007 | 06:18 PM
Montec's Avatar
Try some heat. I cant remember if the dowels are steel or aluminum. i think they are aluminum.
anyway, try putting a little bit of heat on the dowel pin area.
Old Jan 14, 2007 | 06:36 PM
THE CHOP SHOP's Avatar
Mine were steel and rusted nicely. I sprayed them with pb blaster and waited and sprayed more. I got a long screw driver up there and hit the end with a hammer to hopefully penetrate better. I pulled the little black cover by the oil filter and got a pry bar up there. The driver side popped for me first and the pass side was a bitch. Finally I wiggled it back and forth enough and got a flat head between the block and trans and hammered it up. I really did not want to do that but I think that was the only thing that was going to get it out besides heat.
Old Jan 14, 2007 | 06:56 PM
NHRAFORMULA00's Avatar
spray them down with pb blaster, let them soak over night then a pry bar on both sides of the trans will usually do the job!!
Old Jan 14, 2007 | 07:07 PM
TransAminal's Avatar
The other guys gave some good advice. My friends TH350 was a bitch to get out, it was in the car (74 Nova), unouched, for 32 years.
Took a lot of shaking the trans back and fourth, up and down, and tuggin the hell out of it, but we eventually got the thing out
Old Jan 15, 2007 | 07:10 AM
Montec's Avatar
well it there steel then heat would work perfectly, the aluminum will expand faster than the steel dowel pins and theoretically unseize the bell housing from the dowels.
For anybody who tries the heat method just be sure your gas lines or wiring harness are out of the way, you may even want to try a heat shield.
Old Jan 15, 2007 | 08:11 AM
nikon1999's Avatar
i fought with one for an hour, hitt it with pb blaster and let it sit while i ate dinner...went back out and the damn thing popped right out
Old Jan 15, 2007 | 10:53 AM
On lunch right now but I have a screw driver up there by the drivers side dowel but no luck yet Im going to go pic up some pb blaster. Can I get it a the auto parts store?
Old Jan 15, 2007 | 11:25 AM
The1N_only's Avatar
PB blaster is the ****... yes you can get it at most parts stores
Old Jan 15, 2007 | 05:10 PM
just got home from work and sprayed the PB BLASTER on and letting it sit for a little bit I hope this **** works. Im tired of messing with this damn thing!
Old Jan 15, 2007 | 05:12 PM
Black02Bird's Avatar
its called a prybar and a hammer! just make sure the bolts are out first...
Old Jan 15, 2007 | 05:46 PM
After letting the blaster soak for 30 min she slid right off THANKS TO ALL!!! I am the winner of the damn war!!
Old Jan 17, 2007 | 05:29 PM
h8s2w8's Avatar
good deal. i fought w/ mine for a day and a half then I pb blasted and it came right out.
