4l80e ?
Old Jan 14, 2007 | 08:24 PM
DROPTOPLS1's Avatar
Default 4l80e ?
I am looking for a core to have built and put in my SS.Is there any difference besides the tail shaft housing of a 4x2 or 4x4?
Old Jan 14, 2007 | 10:12 PM
8a8mfh's Avatar
The 4x4 will not have a rear reluctor ring on the output carrier, be sure if you're using a computer to control it you have one put on while the output is being swapped. And obviously you'll need a sensor for it too.
Old Jan 14, 2007 | 10:14 PM
2kSnakeEater's Avatar
if they are anything like the 700R4, the 4x4 version tail shaft will be shorter to accomodate the Center Differential, but I could be wrong since its a 4L80E
Old Jan 15, 2007 | 10:44 AM
mach2004's Avatar
The output shaft is shorter on the 4x4 version of the 4L80E as compared to the 2wd version. I'd recommend the 2wd version for this reason.
Old Jan 15, 2007 | 11:43 AM
DROPTOPLS1's Avatar
Thanks for the help seems I will be better off with the 2wd version.
