connections needed or not for the a4 swap
Old Jan 15, 2007 | 05:40 PM
6-Speed Terror's Avatar
Default connections needed or not for the a4 swap
i see in the sticky above that it mentions how to connect when you do have the a4 wire harness but what if you dont have it where do you get the wires from for pnp or shift lock. also if you do not connect that will the car still turn on?
