Nitrous on the 4L60E
Old Feb 3, 2007 | 10:31 AM
J'sRedWS6's Avatar
Default Nitrous on the 4L60E
Finally getting my money situation straight after buying a new truck in October of 06. Ready to keep modding my 2000 WS6. about to go with a VIG3200 Transgo package and Trans cooler. Really wanting to add nitrous just a 100-125 shot prob a HSWwet. gonna do all the safety features like window,heater,pressure safety switch,etc.(prob set window for 200rpms before shift)But Im really worried about the tranny going out, should I be ok, or should I not spray the 4l60e.I hear around 400rwhp is the limit Id probably be around 425rwhp give or take on the spray with pretty much all bolt ons and 3:73s.Also how would a full dynotune affect my shift points with the stall would they raise them a few hundred rpms cuz I dont think that would be good on the trans with the spray.
Old Feb 3, 2007 | 10:55 AM
Mach1killerls1's Avatar
i've been spraying my 4l60e for the last 2 years. once i put in the converter i had to have the tranny shift points lowered and rev limiter raised. just make sure you get a window switch and set it for 5800 shut off.
Old Feb 3, 2007 | 11:45 AM
darrensls1's Avatar
If you're not spraying through the shifts then it should last awhile. The keys to making these transmissions last is a tranny cooler, keeping shift points reasonable (6500 or less), not going into OD at WOT and not spraying through shifts.
If you ever want to spray through the shifts or rev higher then you might want to look at FLT, Performabuilt or Rossler for a heavy duty 4L60E.
Old Feb 3, 2007 | 02:42 PM
Black X's Avatar
I started with a brand new 4L60E put in a transgo HD-2 a Yank 3600 and A B&M supercooler. I make 491RWHP and shut the spray off 100RPM before my 6300rpm shift point. Truck weighs 3850LBS and 60 foots 1.57
I have 36 track passes on this setup with no signs of slippage so far. Every thing seems to be holding up well.
Old Feb 3, 2007 | 06:17 PM
J'sRedWS6's Avatar
Sounds good guys dont think I will need the shift points raised much with the stock head and cam will have the window switch set with first gear lock out and cut off around 200rpms before the shift, really with the window the nitrous would only be used through the 2nd to 3rd shift wont make it to 4th b4 the end of the 1/4mile.Any idea how high the shift points are usely raised with a bolt on, 3:73, 3200stalled car. I would think over 6500?
Old Feb 4, 2007 | 06:51 AM
darrensls1's Avatar
Tuners don't normally raise the shiftpoints too much until a bigger cam is put in. Although a lot of people do raise them on thier own with HP tuners, LS1edit, ect. If your 4L60E is not a professionally built one then I would keep the rev limiter around 6400 or so. But that's just my opinion.
Good luck.
Old Feb 4, 2007 | 12:02 PM
97blkz's Avatar
It will let go at some point IMO but the good news is there are a few shops that can build it right. Not many but a few!
Old Feb 4, 2007 | 12:07 PM
ChocoTaco369's Avatar
Tech Resident
RPM's are the 4L60E's biggest enemy IMO. raising your shift points is a death sentence. if you want your tranny to last, keep them 6,000 rpm's or less. it's something about the pump spring isn't good enough to provide lubrication and cooling past 5500 rpm's. if you raise your shift points to 6500 rpm's or more, you're basically going 1,000+ rpm's over the range that the pump can provide lubrication.
don't spray through shifts, put on a tranny cooler and keep your shift points under 6,000 rpm's and it should last a while. however, nitrous is incredibly deadly to any transmission because it hits it ALL AT ONCE. it's kind of like being punched in the face out of nowhere. whatever happens, expect tranny problems eventually because it was never designed for this punishment.
Old Feb 4, 2007 | 03:31 PM
GregWS6&z28's Avatar
as long as you arent blowing through the converter (you shouldnt be) have at it and stop spraying before the shift as said. My trans builder told me to throw whatever at it I wanted. That's what it was built for.
Old Feb 5, 2007 | 03:02 PM
J'sRedWS6's Avatar
Good thoughts guys.What do you mean? ;as long as you arent blowing through the converter.
Old Feb 5, 2007 | 10:03 PM
Humanoid's Avatar
I hate to be the grim reaper but my car was running 12.0's average on heads and cam and drag radials on many many passes.
Then....I added a 150 shot of N20 with a window switch shifting at 6200rpm....
The trans did not go boom but it quit wanting to 3/4 shift at WOT after about the 2nd n20 pass.
Old Feb 5, 2007 | 10:36 PM
Stang-Slayer's Avatar
my tranny just went out after only 7k on the cam stall and cooler.....only 46k on the entire car :*(
Old Feb 6, 2007 | 03:58 PM
J'sRedWS6's Avatar
Humanoid you were prob around 400rwhp with that head and cam right?Sounds like ur trans held up to that ok.Im sure on spray you were over 500rwhp thats what killed ur trans right? I am pretty scared that the my trans is gonna go out but if it does I should have enough to get a new trans.Im also not gonna spray it alot just make a run it at the track on bottle and off a few times to get my time.Dont see me spraying much on the street,plus its not my Daily.
Stang slayer, Why do you think ur trans went out?cause of the stall or power you were making or ur driving habit?
Old Feb 6, 2007 | 04:17 PM
Humanoid's Avatar
Yes. With the spray I was a bit over 500 hp. That is what killed it..im pretty sure. The kind of tires you are running will be a factor as well.
