stock 4l60e
Old Feb 21, 2007 | 01:50 PM
Omega Doom's Avatar
Question stock 4l60e
My question is this... after I install a yank 4000 or maybe even a 4400 with just long tubes,true duals,UD pulley,tune and a little nitrous 100-150 dry hit will the stock tranny hold up for long? a buddy tells me that the juice will help end it's life and that I should stick to N/A until I can either upgrade the tranny or go with a turbo 350-400 and stall, what do you guys think and any suggestion's or info is appreciated?
Old Feb 21, 2007 | 02:53 PM
Primered's Avatar
Mine was ok with just bolt ons, put the cam in and then went for a tune and the trans started slipping. I would probably do what your buddy said.
BTW, do you not want anyone on the other site knowing about your ls1? Just asking b/c i've never seen you post about it.
Old Feb 21, 2007 | 03:35 PM
performabuilt's Avatar
LS1Tech Sponsor
Probably not for very long if you hit on it much at all
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 21, 2007 | 03:37 PM
bjamick's Avatar
LOL short answer is nope mine didnt make it 3 bottle passes before it started slippping.
Old Feb 21, 2007 | 04:11 PM
Omega Doom's Avatar
you mean on the sauce? so just staying N/A will let it live a little longer? so should I go ahead and go with the Yank PT 4400,4200 or the 4000 for DD? I don't really care if it uses up gas just need it to be dead on reliable in tracfic!
Old Feb 21, 2007 | 05:04 PM
Primered's Avatar
I have a pt4000 and I would easily go with a bigger stall. But if you're going to spray it you don't want more than a pt4000 from what i've read.
Old Feb 21, 2007 | 05:28 PM
Omega Doom's Avatar
well thats just it? I don't want to shell out $900 for a yank if the tranny is going to give up the ghost running juice? I don't really want to switch to a turbo 350 or 400 just yet! I wanted to run a 100 or so shot of juice but only when needed and SEBls1 suggested just going N/A for a while.
Old Feb 21, 2007 | 05:35 PM
Primered's Avatar
Stall, bolt ons, cam and you'll out run 80% of the other board. Keep an eye out for a used yank. I paid 450 plus shipping for mine and it works fine. But it's quite possible the trans will **** out when you do a cam like mine did
Old Feb 21, 2007 | 06:12 PM
Unstang's Avatar
I've rolled the dice on 2 different cars w/ full bolt ons, stalls & nitrous. I've been lucky, so far!!!
Old Feb 21, 2007 | 06:22 PM
ohsofast's Avatar
My old setup I had a 100 dry shot and St 3500 from yank and trans is still good I didn't spray in between shifts, I sprayed from 3k-5,800. Decided to give it to my brother for his project and bought a built one from Performa. for my new setup.
Old Feb 22, 2007 | 06:08 AM
Omega Doom's Avatar
so you used a window switch?
Old Feb 22, 2007 | 01:59 PM
Omega Doom's Avatar
i think I'm going to have to do the same thing!
Old Feb 25, 2007 | 01:14 AM
Omega Doom's Avatar
anybody else with any input?
Old Feb 25, 2007 | 04:33 AM
calongo_SS's Avatar
I've been lucky to say the least. Multiple low 11 sec passes @ 126 mph w/ soft 1.6 60', bolt ons, cam, 4k stall, 150 wet shot, shifting @ 6700 w/ bone stock trans (minus cooler & stall) w/ 68k miles.
That being said, I just dropped off a 4L80 at a local builders shop, it's only a matter of time before that sucker grenades.
