4L80E Swap HELP
What is everyone using as a Dipstick? The firewall mount Lokar piece??
The dust shield tabs are cut on each side, so I should not have any clearence problems and the only thing I should have to cut on the car is on the driverside tunnel for the TCI box to plug into the 4L80E correct??
What about the Tranny cooler lines??? Can I reuse the stock cooler lines and fittings??? Are the fittings 1/4 inch???
The car is a Blower car and I am going to do the Tranny and the motor together at the same time (Thank God I have a Lift literally) Does the TCI Controller come with a Base tune for the 4L80E so I can upload it for break in miles before I slap the Blower belt on??? I wouldn't have any idea how to tune it unless its that easy. BTW do I have to have a Lab top to do so or can I just use my home computer and upload that info from the TCI box?????
Thanks for any help fellows, any other advice I missed I'd appreciate.
Lastly, can you reuse the stock shifter setup from the 4L60E?? I don't want a B&M shifter or anything I want it stock looking. I think I have seen some LS1 guys do that wondering if you guys knew anything about it? The LT1 and LS1 swap should be identical becuase the body shells are the same.
