Roll racing with a stalled auto?
Old Feb 23, 2007 | 12:30 PM
SPRAYED 01's Avatar
Default Roll racing with a stalled auto?
What do you stalled auto guys do on the highway? If your going to race someone starting at 40mph do you just manually put it in 2nd or do you keep it in od and floor it? Any tips and methods would be great.
Thanks
Alex
Not that I race on the street.
Old Feb 23, 2007 | 12:34 PM
ohsofast's Avatar
I put mine in 3rd gear and Yank on it. (pun intended)
Old Feb 23, 2007 | 01:02 PM
SPRAYED 01's Avatar
So you do wait untill it down shifts? I would think a m6 would be gone by the time out cars downshift.
Old Feb 23, 2007 | 01:03 PM
RICEETER's Avatar
thats why you "DIG OR DIE"
Old Feb 23, 2007 | 01:32 PM
jmm98LS1's Avatar
My buddie's stage 3 roush hangs right with me on highway races, but I absolutely rape him from a dig-->15mph roll.
I usually just leave the car in od & hammer the gas.
Old Feb 23, 2007 | 01:50 PM
JstALs1's Avatar
D for me then wack it which usually results in tires spinning street tires suck. I heard that if roll racing on the highway that you should take it out of OD i guess if you leave it in OD it will burn up the bands quicker.
Old Feb 23, 2007 | 02:41 PM
TXZ28LS1's Avatar
i just keep it in OD the whole time!! i dont even try to manually shift on auto!!
Old Feb 23, 2007 | 03:34 PM
RICEETER's Avatar
actually, hard downshifting like all the time will cut your tranny's life in half
Old Feb 23, 2007 | 06:33 PM
DOUBT IT's Avatar
I leave mine in D (3rd), hit the gas and let 'er eat.
Get a big enough stall, and roll racing against a manual car isn't as bad as you think.
Dead spots? What Dead Spots?
Old Feb 23, 2007 | 08:34 PM
BlackHawk T/A's Avatar
There have been many threads on this subject. From those, and my personal experience, my car will stay in the OD selection from now on.
Old Feb 24, 2007 | 10:50 AM
slimcracka's Avatar
40roll= death lol but from 50 its ok leave it in OD and hit it on the second honk..by the time the third honk comes your in 2nd..now for a 10-20mph roll i pull it into 1st and just bump itto OD after we take off..that way i know i get the jump..
Old Feb 24, 2007 | 11:15 AM
Yeah 40mph is not good. You really need to be going 25-30mph for a 1st gear kickdown, or around 60mph for a good 2nd gear kickdown. Leave it in OD for best results (I know, everyone said this was bad before but it was proven wrong).
Old Feb 24, 2007 | 12:55 PM
zigroid's Avatar
when we used to do 20 mph rolls in my 383 LT1 w/ 3.73s I would keep it in 1st gear and stomp it. right as I stomped it I would slide the shifter into 2nd. as the rpms would approach 6500 rpm I would slide it into 3rd and keep it there till I shut down (at about 130 most of the time)
from a 20 roll with all the 383 torque and a 3500+ rpm stall it was DEADLY. surprised alot of guys who think autos arent good from rolls
hell, even from 40 mph rolls I could easily pull several car lengths on stick cars right away.
Old Feb 24, 2007 | 03:17 PM
SilverStang00's Avatar
What would be a good setup to get rid of the dead spots while roll racing. Sorry to hijack, but I will be getting an A4 car soon and I plan on stalling it quickly. Most of the guys around here only roll race unfortunately, so I need all the help I can get. I will be taking it to the strip quite a bit as well.... any suggestions?
Old Feb 24, 2007 | 07:40 PM
gruntwork's Avatar
Thanks
Alex
99% of my racing is on the street and most people with half a brain would rather race an auto from a roll. Hence, I race most people from a roll.
If you leave the car in OD or 3rd and try to leave on the 2 honk, the other guy will react to you motor reving and will gas it before your tranny has time to downshift.
Hold the car in 2nd gear and on 3rd honk, gas it and imediately upshift to OD. I say OD and not 3rd because your trans gets the most line pressure in OD for the 2-3 shift. This won't hurt the tranny. What hurts the tranny is letting the lower gears slow the car down like a manual. If you downshift to roll race, make sure you match the revs and apply more throttle. Don't let the gear slow the car down!!
Old Feb 24, 2007 | 10:12 PM
With my transmission I can't put it into 3rd and expect good results. Reason is, if I floor it from 3rd the transmission will take up to a full 1-2 seconds to downshift. If I leave it in OD, it goes immediately.
Old Feb 25, 2007 | 12:14 PM
97blkz's Avatar
I'd think it would depend on your stall and where you make power.
Old Feb 25, 2007 | 02:36 PM
Gun5's Avatar
lets get some tranny builders in here i know performancebuilt or whatever said its actauly good todo the 1-2 2-3 manually its easier on parts in the 4l60e but if u go into OD manuall well thats another story
from what iv collected and iv seen from my friends racing when im there cars usualy downshift to 2nd then goto OD right when then u hit the gas
Old Feb 25, 2007 | 06:56 PM
That's not right at all.
Old Feb 25, 2007 | 07:40 PM
SuperZ's Avatar
you can have the car in first then right when you floor it shift up into D and it will shift then on by itslef wear its posed to
