Installed th350, PROBLEMS!!!
Old Mar 2, 2007 | 05:41 PM
juicedls1's Avatar
Default Installed th350, PROBLEMS!!!
I just installed my th350 everything went well except for im waiting on my BMR crossmember, my problem is that on my drivers side the oxygen sensor is hitting the shifter lever on the tranny when it comes down to reverse, im reusing my stock shifter and cable! Is there any certain something i got to do to fix it, i thought about getting an o2 sensor with a shorter body, would that work? Thanks in Advance!!!
Old Mar 2, 2007 | 07:02 PM
WE TODD DID's Avatar
Just have the sensor moved
Old Mar 3, 2007 | 12:24 AM
juicedls1's Avatar
Thought about that also! Ill figure something out....
Old Mar 5, 2007 | 09:20 PM
red1999z28's Avatar
I have this exact same problem...right now I'm just running without the O2's...I will probably just move mine.
Old Mar 5, 2007 | 10:28 PM
juicedls1's Avatar
I got a sensor off a 2003 Nissan Altima its about 1/2" shorter and has the same wiring, so i installed it and monitered it with my tuner and reads the same as the factory one so im going torun it for now but im going to have my bung moved and put the stock o2 abck in!
Old Dec 23, 2007 | 04:56 PM
94 guy's Avatar
my linkage hits also anyone figure out how to fix it?
