Overdrive question
Old Mar 11, 2007 | 04:50 PM
Ntimid8r7's Avatar
Question Overdrive question
I did a search on the threads and didnt see anything on this so maybe someone a little more educated on the 4L60e can help me.
When going down the road no matter what speed, as long as it is in OD, little bumps in the road will cause it to go out of OD and right back in. This is my second 4L60, first one stock, this one built so I was wondering if it was normal? I have checked and rechecked the harness and it is all tight. Nothing loose or low on fluids. This TC and trans only has about 25k on it. Any ideas?
It is in my Caprice.....
Old Mar 11, 2007 | 05:19 PM
performabuilt's Avatar
LS1Tech Sponsor
are you sure it not going in and out of lockup
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 11, 2007 | 06:05 PM
Ntimid8r7's Avatar
Yeah, thats what I was trying to say. What would be causing that? Is it just the sudden jolt even though its suttle?
Old Mar 11, 2007 | 08:39 PM
LS1Tech Sponsor
Could be a wire or connector ,Are you getting any ses light ?
__________________
Call 888-744-6542
Old Mar 12, 2007 | 05:19 PM
Ntimid8r7's Avatar
No lights whatsoever. I have double checked everything from the pcm to the harness to the trans and everywhere in between and nothing........My Dad and I traced all the trans wires when I had the engine out to see if we could find anything.
