Another P0757 victim ... need advice
I do have a Vig 3200 triple disk that was installed last June and have not had any problems with it other then having to raise the line pressure 10% because the SES was blinking after the install. Shift points had been changed accordingly.
So....On my drive home I was cruising at around 65 mph, rpms were around 2000, when I tried to speed up. The speed stayed at 65 but the RPM headed up to almost redline. After that I started losing speed and had difficultly keeping highway speed. Several times with high rpms the tranny did seem to shift but I was having a hard time just keeping highway speeds. During all of this the SES was not lit.
I finally got to my exit and the car seemed like it was in 1st gear. I could get some acceleration up to about 3000 rpms then the rpms would just shoot up towards redline and give no additional power. I drove for about 5 minutes like this when the SES light finally came one. The tranny temp on my scan gauges was reading 220 degrees at this point. Luckily I do have a B&M cooler on the tranny or I'd hate to think of what it might have gone up to.
I got home and cleared the code with my scan gauge but the problem did not go away when I restarted the car. I thought the CM might be screwed up so I disconnected the battery over night ...but again the problem still is there.
The SES has stayed off since I cleared it the first time. I've driven the car around the block twice since then to test if I still had the problem.
From what I've read here this seems to be a classic case of a bleed orifice for a shift solenoid being plugged. Any opinions would be welcome.
