Lock up / trans cooler question
I have a '99 Z28 w/ a 3500 stall TCI converter and last summer my buddy and I installed a trans cooler because the tranny seemed to be getting hot when it was running for a while. The reason I think it's getting hot is because when it is locked up, and I give it a good amount of throttle (but not enough for it to downshift) the RPMs will jump up a couple hundred (like the converter is trying hard to stay locked but isn't able) then when I let off, the RPMs go back to their normal spot at that given speed. When the car/tranny hasn't been running long and I do the same thing, the RPMs steadily increase with the speed and the tranny stays locked without a problem.
Anyway, when the cooler was installed, I could run it all day and the tranny would stay cool, but recently the problem has returned, and the tranny seems to be getting hot again. Anyone know what the issue could be? There is nothing blocking air flow to the cooler...
Thanks in advance
