Th-350???
Old Mar 20, 2007 | 03:24 PM
lt1383's Avatar
Default Th-350???
Just got my th-350 rebuild on first turn on.Tranny fluid went all over the place so thinking it was tranny pan gasket was done twice.On 3rd turn on I took better look i notice leak was coming from servo my question is what could i do replace servo.
I know there tool to take off servo, what would be best one too use(servo)? Damn i hate transmission..
Old Mar 20, 2007 | 03:29 PM
street demon2k3's Avatar
Randy, how did the shifter install go? Need track times ASAP you got us all waiting in suspense bro. Get the tranny fixed already!!!
Old Mar 20, 2007 | 03:45 PM
WE TODD DID's Avatar
What servo?
Old Mar 20, 2007 | 04:27 PM
8a8mfh's Avatar
The cover on the side is an accumulator, they probably used a B&M **** kit, yes **** kit. It says to leave the spring out but when you do that it doesn't push the cover on enough to seal it. I'd put the spring back in with a new o-ring and run it like that or put a 1 1/8" x 5/16" pin in the hole under the plug near the accumulator to block fluid flow to it.
You need no special tool to remove the cover, tap it in and insert a long 1/8" allen wrench or pin, awl, etc into the small hole in the case on the other side of the retaining ring, this will push the ring out enough to grab it with needle nose pliers.
But chances are real good it's really leaking from the detent cable or dipstick.
Old Mar 20, 2007 | 11:37 PM
lt1383's Avatar
Thanks for help guys should be getting this done later on today...Lines,dipstick had been check it damn circle next to lines which was told its called servo, ill be done an see track on friday..
Old Mar 20, 2007 | 11:47 PM
Thats just the accumulator. If the o-ring isn't installed just right, it will leak every time.
Old Mar 21, 2007 | 12:15 AM
lt1383's Avatar
It leaks out when its ON, Damn hope everything work with new oil ring...What else need to be replace?
Old Mar 21, 2007 | 12:31 AM
8a8mfh's Avatar
Cooler line, make sure you don't have the thin walled trans fittings, they crack easy.
Could very well be a cooler line leaking.
