If I change from a 2.73 to a 3.42 rear, do I need to adjust shift points?
Old Sep 19, 2002 | 10:36 PM
squirrels's Avatar
Default If I change from a 2.73 to a 3.42 rear, do I need to adjust shift points?
I've been thinking about getting a 12-bolt 3.42 rear to replace my 2.73 stocker. However, I don't have a lot of money right now to spend on a laptop and Autotap/LS1-Edit.
SLP sells a module that will plug into your PCM and reprogram the speedo. Now if I go from 2.73 to 3.42, is that enough? Or will I also have to make adjustments to the shift points (i.e. the MPH at which to shift and such)?
Thanks
Mark
Old Sep 19, 2002 | 11:17 PM
wrencher's Avatar
wrencher
Default Re: If I change from a 2.73 to a 3.42 rear, do I need to adjust shift points?
I would recommend getting it tuned . But the slp thing should work!? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Sep 20, 2002 | 08:49 AM
Paul F's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by squirrels:
<strong>I've been thinking about getting a 12-bolt 3.42 rear to replace my 2.73 stocker. However, I don't have a lot of money right now to spend on a laptop and Autotap/LS1-Edit.
Thanks
Mark</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You don't have to adjust shift point if you don't want to. If you correct the speedo to the 3.42s then the shift points should be the same as you have now.
