What RPM should the 4160e/shiftkit ?
Old Mar 26, 2007 | 04:29 PM
SS SLP2's Avatar
Default What RPM should the 4160e/shiftkit ?
have LS1/4160e/shift kit/stall/Lot of boltons/cam making power to 6800/3.73,
having problems with laging wot shifts if over 6000, please advise as to rpm,
members/drivers are winding to before shifts and if you are having this problem AND how to correct ( tran complete rebuilt/ zpack/ shift kit/??)
please some one /every one offer advice
Thanks ,Johnny
Old Mar 26, 2007 | 05:00 PM
performabuilt's Avatar
LS1Tech Sponsor
Do you know if the pump slide spring was replaced with the sonax or some other mod to make it stronger that stock , The Pump slide with the stock sping can begin to allow the pump to colapse over 6000 RPM this can cause the line presure and volume capabilities of the pump to drop substaintially above that RPM this may cause delayed shifts, soft shifts, longer that desired elapsed time from command to actual shift.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 26, 2007 | 05:08 PM
SS SLP2's Avatar
i do not know but will ask in the morning
THANKS, Johnny
