What OD tranny to use?
Note: I drive a lot. I need overdrive. And want to do this for a reasonable price, so unless you have a $500 Gear Vendors unit, it's not a consideration.
on the street 150 shot i never had a problem though i had aftermarket clutces ect.. but even without spraying it went in 1 day at the track hooking, then i replaced the part that broke with a stronger one and replaced the clutches again and it lasted 8 passes the second time before it broke that same stronger more expensive part again lol
I'm not joking I will do it! 4L60E =
