Converter question, technical....
If so, if I'm doing say 50mph in 2nd gear, well over 3000 rpm, will it be locked up? So when I hit it from that 50mph roll I'll be equal to a stick car going 50 along side me?
Thanks
<strong>Converter will not lock up under WOT, unless you do it w/LS1 edit or a lockup switch.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So, if I'm doing like the example said, I can hit a button, locking the converter at 50mph and be equal to a stick car?
Can I lock it up after a launch?
Whats up with a lock-up and non-lock up?
Which is the best for the street? 460 RWHP/TQ
If you need to lock-up because your converter is inefficent, top of 3rd gear is where you do it.
