Wont go into Drive?
Old Apr 1, 2007 | 07:19 PM
Gordon0652's Avatar
Default Wont go into Drive?
I have a stock 2000 T/a A4 with about 13-14 thousand miles on it, and i rarely drive it. Just the other day i started the car, and let it warm up, and then put in D and it wont move, and i wasnt giving it gas. Then i gave it gas to about 2,000rpm, and it was only going about a mile an hour. What could be wrong? I never redlined it, or drove it hard, or pasted 90mph.
Thank you!
Old Apr 1, 2007 | 07:21 PM
performabuilt's Avatar
LS1Tech Sponsor
Are you sure it wasnt actually in 3rd gear limp mode it will feel like you hav to give it alot of gas to move untill you get going and will not change gears, I would scan for codes first,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 1, 2007 | 07:22 PM
FLT's Avatar
FLT
You should probably verify that it is full of fluid and also check it for codes.
Old Apr 2, 2007 | 05:31 AM
Gordon0652's Avatar
Well i tried it agein, and i cannot get it to do it agein. So i am guessing it had a bad day, but just to make sure i am going to take it down to GM, and have them check it out.
Thank you for the help!
