Fuddle Converters?
Old Apr 4, 2007 | 06:26 AM
importhater1's Avatar
Default Fuddle Converters?
http://www.fuddleracing.com/Clearance.html
How are these converters compared to yanks and other converters? I want a good converter and want to shave off of at least .5 seconds on my 1/4 mile. Will the fuddle 3400 stall be a good performer at the track and as an everyday driver? let me know your thoughts. thanks
Old Apr 4, 2007 | 12:04 PM
ARCTICWHITE98Z28's Avatar
I have a 3400 Fuddle w/ 2.1 STR. Before the converter and Nittos DRs I ran 13.8 bone stock. With the converter and DRs I ran 12.9. It makes a world of difference from a dig. I have about 20,000 miles on my Fuddle and it still works great. Recently I started spraying a 100 dry shot and this converter holds up fine and seems to be a good stall rate for nitrous. Just make sure you get a good tranny cooler no matter what converter you get. I have the B&M 24,000 model. You definitely don't want to smoke your tranny just because you added a high stall converter.
Old Apr 4, 2007 | 12:54 PM
4yall2nv's Avatar
i have hit consistant 12.1s with a fuddle 3600, have cut consistant low 1.60-60 foots on et streets! this is on just bolt ons!
Old Apr 4, 2007 | 10:51 PM
Casey2323's Avatar
Default fuddle
Fuddle builds a top notch converter .. his units are just as nice as the other guys but much more reasonable
Old Apr 4, 2007 | 11:17 PM
DisturbingDaPeaze's Avatar
i run 12.1 with 1.54-1.58 60 fts. lift driver side tire a tad.
mine is only a 3400
