need help with 4l60e
Old Apr 6, 2007 | 12:21 PM
justin quick's Avatar
Default need help with 4l60e
My pops and i are building a 32 ford roadster and have installed the ls1 egine and 4l60e outa my 98SS in the 32. The car will only weigh 2000 pounds and i have full bolt on's and a 228R tsp cam in it. What size stall would i need taking into consideration that the car only weighs 2000 pounds. Does weight play a role in stall/ torque converter selection. thanks in advance.
Old Apr 6, 2007 | 12:32 PM
CharlieLed's Avatar
Curb weight shouldn't affect the stall, stall allows engine to spin up to the correct torque range before engaging the convertor/trans. Use your current TC and you should be fine.
Old Apr 6, 2007 | 01:02 PM
cool thanks man wasnt sure and didnt want to buy anything without knowing.
