VSS for th400
Old Apr 9, 2007 | 05:49 PM
98turbls1's Avatar
Default VSS for th400
Does anyone know where you can get a Vehicle speed sensor and drive rotor for a TH400 that will be compatible to the LS1 speed sensor plug? Is there anything that is compatible with it in say a late 80's early 90's tranny? Thanks in advance.
BTW search is down.
Old Apr 9, 2007 | 06:49 PM
SLowETz's Avatar
VSS from a 1990 454 3/4 or 1 ton 2wd truck will work. Cut the wires and splice together, or tap into the WSS wires.
Old Apr 9, 2007 | 08:56 PM
8a8mfh's Avatar
Depends on the output shaft size. 4" tail all have 32 spline large reluctor ring.
Typically the late 80's and early to mid 90's th400's had 27 spline 9" tails with the small (ID) reluctor ring.
Try the search again, I'm tired of people telling me to try a search and I'm tired of answering the same questions over and over.
