What is that best transmission fluid to use?
Old Apr 14, 2007 | 11:50 AM
BLACKHAWK1998's Avatar
Default What is that best transmission fluid to use?
I'm using Mobil 1 Synthetic ATF Multi-Vehicle Formula.
Old Apr 17, 2007 | 07:30 PM
anyone?
Old Apr 17, 2007 | 07:37 PM
Ragtop 99's Avatar
I used plain old GM Dexron III. It's designed to work with your clutch materials and if you're flogging the car you should be changing it much more often than the owner's manual suggests.
Old Apr 18, 2007 | 04:59 PM
BlackHawk T/A's Avatar
Dex 3 or 6.
