shift kit
Old Apr 14, 2007 | 12:17 PM
speedracer1280's Avatar
Default shift kit
My trans has 92,000 miles...would u suggest a rebuild first...also will be installing a vig stall .....
Old Apr 14, 2007 | 12:58 PM
orangefun's Avatar
if you are going to put a stall in I think you should have your tranny gone though, I mean you will already have the tranny out might as well.
Old Apr 15, 2007 | 09:59 AM
that stuff gets so expensive though....tired of waiting and tring to save the money....i know its the right thing to do though....well i have not done my taxes yet...i see how much i will be getting back...then i think about it....thanks...
Old Apr 15, 2007 | 01:46 PM
Montec's Avatar
pay a little now or a lot later. Go thru it now and have it freshened up instead of later and risking tearing up hard parts when it goes bad.
Old Apr 17, 2007 | 04:42 PM
what rebuild kits are ya'll using? I will not use tci...bottom line...what about hughs...I've heard they have good convertors and the rebuild kit they have sounds like it has HD parts in it...its like around 400$ so it better be good
Old Apr 17, 2007 | 10:05 PM
dpw41285's Avatar
borg warner or red alto. a stall will more than likely wipe your tranny out in days... then what if it takes the new stall with it. Sounds like you cant afford not to rebuild it now.
Old Apr 17, 2007 | 10:07 PM
The93z's Avatar
I dont know depends on how your tranny and engine is running right now. I just ordered a shift kit and i have 82k, my tranny is slipping though
