check engine light after th400 install
Old Apr 14, 2007 | 12:21 PM
SuperZ's Avatar
Default check engine light after th400 install
Since I did my Th400 install from a M6 my service engine soon light has been on.Is there somthing I can do to get it off?Im guessing it has to do with some of the M6 harness stuff not being plugged in anymore
Old Apr 17, 2007 | 09:05 PM
Hugh betcha's Avatar
You are correct the check engine light and trouble codes can be programed out. Find someone with LS1 edit (shop edition) or similar programmer and they can take care of the light for you. Some sponsor on this site will eventually see this post. Post where you are located for them. I sent mine out for programming but I found and documented all of the related trouble codes first.
