yank lock up settings
Old Apr 22, 2007 | 11:21 AM
IROC403's Avatar
Question yank lock up settings
hi, everything seems ok, but at highway speeds the lock-up stays
for a few minutes then unlocks for a few.is there a value to adjust
to keep it locked???? i have efi live, but im a newbie with it.
any help would be cool.
Old Apr 22, 2007 | 11:40 AM
performabuilt's Avatar
LS1Tech Sponsor
typically if it locks and then unlocks repeatedly its a sign of and engine missfire code just and idea.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 22, 2007 | 11:47 AM
BlackHawk T/A's Avatar
I would look at the tune and play with the misfire settings.
Old Apr 22, 2007 | 12:51 PM
Rhino79's Avatar
Ditto.
Old Apr 22, 2007 | 04:44 PM
Dan's Avatar
Dan
ditto+1..Just up the misfire codes, that should cure the problem..It was weird because I had a vig 3800 with no problems, then went to a Yank SS4000 & it would lock & unlock..raised the misfire codes & it stays locked all the time.
Old Apr 22, 2007 | 05:57 PM
IROC403's Avatar
thanks, that sounds easy enough.will try it in the a.m.
