Burnout in 1st or 2nd?
Old Apr 25, 2007 | 09:38 PM
Brief Encounter's Avatar
Default Burnout in 1st or 2nd?
Hello all,
Search is down, so in short my question is...
When doing a burnout in the waterbox, should I be in first or second?
I ask this because while talking to a few car guys they said it is hard on the tranny doing a burnout in 1st, and I should put it in second.
Is there any thruth to this, or is it all a bunch of non-sense.
thanks for the help!
Rich
Old Apr 25, 2007 | 09:49 PM
darrensls1's Avatar
I heard the same thing so I do all my burnouts in second. I figure it helps protect against bouncing the rev limiter by accident and it makes one less position I have to move up on the shifter when I stage.
Use 2nd gear FTW!
Old Apr 25, 2007 | 09:57 PM
Dbluegoat's Avatar
i do 2nd, and I find great success in that too.......
Old Apr 26, 2007 | 07:53 AM
Ragtop 99's Avatar
I did mine in first gear so the tranny didn't shift while doing it.
Old Apr 26, 2007 | 09:01 AM
jay_99z's Avatar
I put it in 2nd, bring the RPM's up to 6K and hold it til the smoke rolls. Never had a problem with the trans.
Old Apr 26, 2007 | 09:37 PM
BlackHawk T/A's Avatar
Why would the transmission shift on you?
If you are in 1, you stay in 1st even to the limiter. If you are in 2, you start in 2nd and stay in 2nd to the limiter.
At least that's what both my stock and built transmissions have done.
Old Apr 26, 2007 | 09:56 PM
Ryan K's Avatar
Pathological Modifier
not true for all years... 98's don't have second gear start...
Ryan K.
Old Apr 26, 2007 | 10:41 PM
performabuilt's Avatar
LS1Tech Sponsor
Yes some cars will not stay in first even though manually selected the PCM can overide and cause and upshift to second. Now you can hold it down in second as long as you like, This is and issue the transgo kit tackles by changing the valve so the car can stay in first reguardless of what the PCM comands
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 26, 2007 | 11:20 PM
6-Speed Terror's Avatar
if the tranny is built and you put selector on 2nd will it start in 1st then shift, or will it just start out in 2nd?
Old Apr 26, 2007 | 11:23 PM
waterbug1999's Avatar
Hell, I just put the Line Lock on and hit the gas in D... Works well for me!
Old Apr 26, 2007 | 11:59 PM
nitroushane's Avatar
I do 2nd gear, just so I can get the tire speed up to really get the tires nice and sticky.
Old Apr 27, 2007 | 12:07 AM
LS1Tech Sponsor
Depends our level 3 will hold first forever but the PCM can override most units
__________________
Call 888-744-6542
Old Apr 27, 2007 | 07:49 AM
FLT's Avatar
FLT
It is always best to leave the shifter in the d-3 position. Start out by doing your burnout in first until the trans is in third and then let off the break. In third gear all the transmissions internals are spinning 1 to 1. This will greatly reduce blowing out the low roller or input sprag when performing your burnout. This same info was presented to me as a young racer from a veteran builder/racer. After I learned the power flow of what is happening inside of these evil transmissions, it made a lot of sense. Vince
Old Apr 27, 2007 | 08:00 AM
RevGTO's Avatar
Pontiacerator
I typically start in first, shift into second, and roll out in second. Is that bad?
Old Apr 27, 2007 | 08:33 AM
DannoWS6's Avatar
Linelock---> D ----> Pedal--->
Old Apr 27, 2007 | 12:08 PM
jay_99z's Avatar
I used to do that too. When I swapped to slicks and 4400 stall the tires would stop spinning sometimes when it shifted into 3rd. I'd have to really get into the gas to break them free again. Didn't think that was too good on everything.....getting a hot sticky tire to spin. Maybe my car is just weird but I've never had a problem with 2nd gear burnout.
