@ WOT buzzed the REV limiter, on 2-3 shift!
Regarding tuning if posted up a scan from HP tuners what that be of any help?
thnaks
Rich
Rebuild time.
It happened to mine with about 45k
Fully built now hi-po servos, reinforced sun gear and new bearings, kevlar clutches, shift kit, and hi-stall.
Too many burnouts and manual shifts were my pitfall.
Good luck.
I am going to drop the shift point to 5800 rpm, and keep moving it up till it starts not shifting again. Someone told me that a stock 4L60E will not survive very long when it see 6000+ rpm's, is there any truth to this?
Not that it makes a difference, but I have a Trans-Go shift kit sitting on my tool bench, would it be possible for me to bump up the line pressure enough to hold at 6000+ RPM's.
O, and I will not put in a New auto tranny, As soon as I have enough funds, I will be doing a T56/ 9inch swap.
200+ passes...last 50 or so on a 100-125 shot out of the hole shifting at 6300
In your case though if would probably work well if you are wanting to start in D to move the selector to the OD position right after the 1-2 shift and that should avoid this issue. Hope this helps.
