Trans cooler question?
Old May 4, 2007 | 09:06 PM
transam69230's Avatar
Default Trans cooler question?
I just want to make sure that when i run my cooler lines, which is the in and out on the trans.
Old May 4, 2007 | 11:25 PM
blkbird_WS-6's Avatar
If you are referring to which place on the cooler to hook up, it doesn't matter. If you are referring to the tranny then bottoms out and tops in on every GM tranny except for the 200R4 then it's reversed.
Old May 5, 2007 | 03:45 PM
Thanks
