PWM question?
Old May 6, 2007 | 01:01 PM
firebirdls1us's Avatar
Default PWM question?
I have a level 4 rock-on and it's modulated so do I even have pwm?If so can it be turned off with hp tuner..........I already have my tcc duty at max.100 min.98.is there anything else I can do?
Thxs.
Old May 6, 2007 | 02:37 PM
8a8mfh's Avatar
Thxs.
The tcc signal is Pulse Width Modulated.
A modulated 4L60E usually refers to it being converted to vacuum modulation where the force motor is removed and a vacuum modulator put in it's place.
This has nothing to do with the tcc duty cycle.
What are you trying to accomplish?
Old May 6, 2007 | 05:08 PM
just trying to be sure that pwm has no effect on my tcc locking or unlocking is all
Old May 7, 2007 | 01:55 AM
PBA's Avatar
PBA
If it is a RockOn unit the pwm is changed to a on/off valve from TransGo. Dave always does this from what I have seen.
Old May 7, 2007 | 06:59 PM
okay thxs. I was hoping that also
