2007 vette 6 speed auto trans
Old May 6, 2007 | 01:55 PM
paulgto's Avatar
Default 2007 vette 6 speed auto trans
what is this transmission rated at? and is this a better option then rebuilding my 4l60e? or swapping for a 4l80e?
Old May 6, 2007 | 04:06 PM
paulgto's Avatar
Default well>
anyone?
Old May 6, 2007 | 04:28 PM
Tainted's Avatar
i doubt it will even work
Old May 6, 2007 | 04:31 PM
billasz28's Avatar
Old May 6, 2007 | 05:35 PM
ChocoTaco369's Avatar
Tech Resident
as far as i know, at this time, it is impossible to swap a 4L60E for a 6L80E. it may be possible in the future, but for now, your options are a built 4L60E, TH350, TH400, 4L80E and powerglide.
Old May 6, 2007 | 10:28 PM
kaos_'s Avatar
man a 6 speed auto would be a dream!
Old May 11, 2007 | 08:44 PM
dknight16's Avatar
582Nm input torque. The controller is internal to the trans (requiring a totally different vehicle wiring harness hook-up). This would be a very difficult if not impossible swap.
Old May 12, 2007 | 01:23 PM
XLR8TOR's Avatar
Isn't the vette trans rear mounted?
Old May 12, 2007 | 03:32 PM
BlackHawk T/A's Avatar
Pointless. More gears just gives you more shift time and more parts to break. Get a properly built 4 speed with the right converter and you will have the correct powerband.
Old May 12, 2007 | 07:25 PM
dknight16's Avatar
Yes. It has no case extension and uses a very shallow bell housing that mates to a torque tube (connected to the engine).
Old May 13, 2007 | 10:17 PM
Soccerbum21's Avatar
i was wondering how difficult that swap would be too
not that i'm interested in doing it. more like curious to see if the classic GM parts-swap fest would work to our favor again
Old May 13, 2007 | 11:18 PM
performabuilt's Avatar
LS1Tech Sponsor
from what i have seen near impossible
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 14, 2007 | 02:47 AM
spy2520's Avatar
maybe there will be an 09 GTO/Camaro option that may fit in our cars. i cant see the benefit besides highway mileage, and even then i'm pretty sure the 6th gear isnt far from our 4th.
Old May 14, 2007 | 09:19 AM
dknight16's Avatar
6L80 gear ratios:
1st: 4.027
2nd: 2.364
3rd: 1.532
4th: 1.152
5th: 0.852
6th: 0.667
overall ratio: 6.04
Old May 14, 2007 | 04:22 PM
GrnDragon's Avatar
Why is everyone so concerned with the programmer? Why can't they just be setup as a manual shift auto, once B&M or Hurst comes out with a shifter? Having a 6 speed without a clutch would rock!
Old May 14, 2007 | 04:54 PM
kaos_'s Avatar
i would think i was in heaven if i had an auto 6 speed in my car. no more getting pulled by t-56 in the top end! or do i just need a higher stall?
