Transmission Conversion
Old May 15, 2007 | 10:18 PM
the_merv's Avatar
Veteran: Air Force
Default Transmission Conversion
Alrite.. this is what I am looking at..
I have a nicely Built LT1 4L60E, and I have a stock LS1 4L60E that I got for real cheap.
This is what I am thinking..
Take both them apart, switch the Wiring, Solenoids, and the Imput Shaft of the LS1 Tranny to the LT1 Tranny, keeping all the good stuff in it, upgrade some of it, and then bolt it to my 402 LSX Engine and drop it in the Car.
I have a builder that has no problem doin all of this, we are both researching it. The reason we are switching the Imput Shafts out is so I can use my LS1 Stall in it to make it easier. I want to keep the LT1 Tranny cause it will mount up in the Car where it should when I do my swap.
Old May 16, 2007 | 12:56 AM
the_merv's Avatar
Veteran: Air Force
Where's that one guy at that knows all this little stuff...
Old May 16, 2007 | 07:59 AM
performabuilt's Avatar
LS1Tech Sponsor
Well your going to have a clearance issue with the LS1 converter the bell wont be deep enough . Though it might be possible to get a frankenstien converter I have not seen the swap done this way.
What type engine are you using and LS1 or early style?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 16, 2007 | 10:56 AM
jay_lt4's Avatar
all you need is the hughes crankshaft spacer and you can bolt the complete lt1 trans and lt1 converter to your ls1:
check it out::
https://ls1tech.com/forums/automatic-transmission/639693-ls1-style-engines-old-style-trans-th350-400-2004r-700r4-4l60e.html
Old May 16, 2007 | 12:14 PM
LS1Tech Sponsor
Yes but he wants to use his ls1 converter in the LT1 transmission
__________________
Call 888-744-6542
Old May 16, 2007 | 01:46 PM
the_merv's Avatar
Veteran: Air Force
It's a 9.5" Convertor.. so I have a little bit of play room cause it's not that wide.
Basically the Intention is to take the LT1 Tranny and bolt it to the LSX Block, use the LSX Convertor.
