hard to install shift kit?
Old May 19, 2007 | 10:31 AM
cals400ex's Avatar
Default hard to install shift kit?
i was debating on getting a shift kit but i had no idea how hard it was to install. i don't know a ton about tranny's. if it comes with good directions then it may not be a problem. i don't even know if special tools or anything like that is needed....
Old May 19, 2007 | 10:51 AM
FLT's Avatar
FLT
They do come with pretty good directions. If you have pretty good mechanical abilities it should be pretty easy for you. As far as special tools, a pair of small snap ring pliers with small tips will be needed to remove the pressure regulator springs and the boost valve. An inch lb torque wrench would be a good idea as well to properly torque the valve body and the transmission oil pan. Other than that some basic sockets will be required and a small pick or screw driver. I hope this helps. Vince
We do sell the parts for this if you are interested check out our site.
