pics after trans willnot shift into 3rd
Old May 19, 2007 | 07:31 PM
spec_j's Avatar
Default pics after trans willnot shift into 3rd
as most have seen in the other thread, my trans will not shift into third gear... well I dropped the pan, and this is what I found.
here are some pics after dropping the pan.
I hope this isnt what I think it is.... im going to be sick...
Old May 20, 2007 | 09:33 PM
Greaseymec's Avatar
Looks like it needs to come apart. 3-4 clutches are probably done for. Looks like a piece of friction material that you are holding. A very "cooked" piece.
Mec
Old May 20, 2007 | 10:12 PM
c0ncEpT's Avatar
I changed my fluid on Friday after my trans would not shift the 2-3 shift without hitting the limiter at the track the week before and my pan didn't look that bad but the magnet was similar with the amount of **** on it and now the trans seems to shift as good as it has ever now that it was changed
Old May 20, 2007 | 11:17 PM
spec_j's Avatar
that was the case for me the first time, i was lucky that it was only the fluid. This time im not so lucky. I did the fluid and it did nothing. So im going to replace the solenoids and see if thats what it is, if not im going ot start saving for another build trans. This will be number 3 i think, maybe 4.
