TH400 Question
Old May 23, 2007 | 05:57 PM
Sprayed1998's Avatar
Default TH400 Question
Im not sure you guys will be able to help me but it's worth a shot. Anyhow my dad just bought a 1970 Olds 442 with a 455/TH400/12 Bolt. When we 1st got it it shifted really hard, I mean it jerked you around bad. We swapped out the vacuum lines and the modulator and it pretty much fixed the shifting problem, I guess it was leaking or the modulator was just bad.
Anyhow the problem is when you are in park, and you go to put the car in reverse or drive it will jerk really hard. Pretty much feels how it did when it used to shift hard but it only does it when you go from park to R or D. Does anybody have any ideas or fixes for this problem. Thanks.
Old May 23, 2007 | 10:34 PM
WE TODD DID's Avatar
High line pressure will cause that. Fast idle will cause it too.
Old May 23, 2007 | 11:03 PM
5_02ls1's Avatar
do you have the vaccum on part time if not thats your problem...or try a adjustable modulator
Old May 23, 2007 | 11:11 PM
performabuilt's Avatar
LS1Tech Sponsor
Actually in late h400 they fixed that but it is relatively normal for early models
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
