A4-M6 swap.is the wiring the same as 97' for a 99'
Old Apr 30, 2003 | 10:16 AM
BLKWS6's Avatar
Default A4-M6 swap.is the wiring the same as 97' for a 99'
I found swap instructions for a 93-97 A4-M6 swap. They used the A4 harness and made it work. Is this possible to do on the 98+? i can get the pigtails they needed, but i dont know if the wire colors are the same.
Anybody know????
Old Apr 30, 2003 | 01:48 PM
BLKWS6's Avatar
Default Re: A4-M6 swap.is the wiring the same as 97' for a 99'
Somebody has to know this???
Old Apr 30, 2003 | 02:22 PM
LS1x2's Avatar
Formerly 4mulaJoe
I don't know if it's the same but one way or another it is possible if you splice into the wires b/c you can use the same pcm with a different flash file.
