Powerglide ?
Old May 30, 2007 | 01:07 PM
AMS 72's Avatar
Default Powerglide ?
Has Any One Drove An Ls1 Much With A Powerglide.
Car Is Basically Stock W/exception Of A 9" W/4.11 Gears
What Is Drive Ability Like
Old May 30, 2007 | 01:18 PM
performabuilt's Avatar
LS1Tech Sponsor
Well you will have only two gears one moderatly low and the other 1 to 1 with 411 gears you can figure 3300 to 3600 rpm at 55 mph , Not very drivable, You also will not have lockup so if you have a hi stall again and issue. Powerglide is generally considered race only stuff
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 30, 2007 | 02:38 PM
AMS 72's Avatar
i built this trans myself and have built many others. in my opinion just because its a powerglide doesn't mean its a race only tranny, i was just wondering if anyone had this combo after an a4 tranny, and if so was there any et gains over the a4.
Old May 30, 2007 | 02:41 PM
LS1Tech Sponsor
I didnt say you couldnt drive them on the street just to me having 2 gears would be bad. Not having overdrive would be worse and having just two dosent seem fun I am actually old enough I have driven quite a few powerglide cars back when they came from the factory that way lol
__________________
Call 888-744-6542
Old May 31, 2007 | 07:19 AM
AMS 72's Avatar
thats cool, I aint tryin to sound like an a** I just want to know how these cars react to powerglides on the street. i know its going to pic it up on the track.
Old Jun 1, 2007 | 03:05 PM
Anonymous's Avatar
10 second playa
So you are saying you can't get a lock up converter for a glide?
I know you can get a dual stall converter with the fluid-by-pass.
One for launch and one for 2nd gear to run it out the back door.
Old Jun 1, 2007 | 03:39 PM
jmm98LS1's Avatar
I was under the impression that 'glides work better in lighter cars (like 3200lbs or less), and th400 was a better match for heavier cars.....both track and street.
Old Jun 1, 2007 | 03:51 PM
NoGamesLS1's Avatar
Glide w/4.11= unless you go with taller tire. Stock tire you will be about 112mph @ 6000rpm. If you are looking to put in a glide to lower your et I hope you are trapping more than 110-115mph. I believe a 29 in tire will put you in the area of 140mph @ 6000rpm though.
