4L60E disassembly
Old Jun 6, 2007 | 03:29 PM
350SS's Avatar
Default 4L60E disassembly
Sorry for posting a truck app on the car forum, but I figured I'd get more action over here.
Long story short, busted 4L60E....Well, after being jacked around by a local wrecking yard (the transmission I picked up from them had dirt embeded in the input shaft splines and inside the torque converter), I've decided to take a shot at rebuilding the 4L60E transmision from my Tahoe myself or at least disassembling it myself first. I'm about halfway done getting the internal components out but can't seem to be able to get the Input Sun Gear to pull out off of the output shaft.
Can anyone recall if there is a trick to this or if I just need to go rent a puller to pull it off the shaft? There isn't much detail about this in the ATSG manual. It's a 97 4wd 4L60E btw...
Old Jun 6, 2007 | 05:46 PM
Predator T/A's Avatar
i the sun gear wont come off that means that the sun or the planets are damaged they do make a puller for getting that off when its damaged....but you should be able to just slide it off but the gear is damaged and that is why its not coming off..
Old Jun 6, 2007 | 05:47 PM
get a pair of vise grips and i hope you are strong lol
Old Jun 6, 2007 | 05:52 PM
350SS's Avatar
You beat me to it. Went and rented a generic gear puller and got it out. Pretty chewed up. Oh well... Thanks for the reply!
Old Jun 6, 2007 | 05:55 PM
always glad to help lol......i have had a few like that had one that i had to ACETYLENE out lol
Old Jun 6, 2007 | 05:56 PM
since you need a planet and sun anyway get a 5 pinion setup for both planets
Old Jun 6, 2007 | 06:05 PM
350SS's Avatar
I would but with all this **** adding up, I'll probably go back to the drawing board and try to find a decent one at a wrecking yard. This is just for a stock rebuild anyways.
Old Jun 6, 2007 | 06:27 PM
i think i have an extra front planet i f not i can get one for about 30 bucks
Old Jun 6, 2007 | 08:34 PM
big wally 55's Avatar
The problem with a bone yard unit is some of them are there for a good reason !! You can do a little checkout on a unit by taking a pair of channel locks with you an take the trans out of park and you should be able to turn the output shaft in both directions , a little more resistance will be felt in 1 direction as you are turning the entire gear train . the one you tore down wouldnt have turned !! Have fun and good luck . John
Old Jun 6, 2007 | 10:20 PM
350SS's Avatar
That's a good option, although now that I got the input gear out, I can't get the planetary out now I imagine it's for the same reason. I'll probably will end up needing the whole assembly. And who knows what else when I get the rear set out
Old Jun 6, 2007 | 10:23 PM
350SS's Avatar
Thanks for the heads up and the tip.
