Thinking about doing a stall....
Old Jun 6, 2007 | 07:30 PM
firebirdman469's Avatar
Question Thinking about doing a stall....
I am wondering about stalls and what I should go with. I have pretty much made up my mind on a Yank SS3600, what is your opinion?
Also, if I go with that stall what trans cooler should I go with? I have heard that a B&M Supercooler for 16k GVW should work great....opinions?
And, should I go with a shift kit to help make the shifts more firm? If so, is the Transgo hd2 shift kit the way to go?
Are there any other things I should consider getting when I do the swap?
Thanks again,
James
_____
Old Jun 6, 2007 | 08:38 PM
Raise's Avatar
i just put a yank ss3600 in my 02 bolt on z28. from what ive read, i wouldnt go under a 24k cooler, just to be safe. mine i think around 28k. the higher stall like we have will make shifts feel a little soft and sloppy, so a shift kit is not a bad idea. im still takin it easy for a couple hundred miles, but i cant wait to get on her. the yank ss3600 seems to be one of the most popular converters for our cars. good luck man
Old Jun 6, 2007 | 09:04 PM
STRETCH'S T/A's Avatar
I also have a Yank SS3600, and agree with Raise as well, 24k cooler min. Shift kit wouldn't hurt. Also look into getting a deeper trans pan as well.
Old Jun 6, 2007 | 09:08 PM
silverws600's Avatar
go with ss3600 and you wont regret it!
_______________________
2000 Ws6 A4
Old Jun 6, 2007 | 11:37 PM
nofearracing28's Avatar
Stall, cooler, shift kit. Then, suspension mods will be needed next!
Old Jun 7, 2007 | 12:25 AM
99 Predator's Avatar
just put in my ss3600 with a B&m 24k and shift kit, seems to be the most popular stall. just make sure u have some nice tires when u put the stall in
Old Jun 7, 2007 | 10:13 AM
So I am guessing you like your setup?
How does it drive on the street, from 0-40?
Old Jun 7, 2007 | 10:44 AM
Bryan @ Speed Inc.'s Avatar
good advice
Old Jun 7, 2007 | 10:59 AM
just some food for thought - i saw your location... you can buy a Precision Industries Vigilante converter from Speedinc out of schaumburg, il ...and you would see it in 1-2 days.
Yank and Vigilante are the best two brands out there, but Yank doesn't deal with shops anymore, and i heard they were backed up a couple weeks from a local guy.
www.ls1speed.com - they'll set you up with the right converter for your application. you can also order transgo shift kits from them and get them all in the same order.
Old Jun 7, 2007 | 12:54 PM
I have checked out other converters, and I think I am sold on the SS3600. What deep pan do you guys recommend? Or are they pretty much the same?
Old Jun 7, 2007 | 09:32 PM
The deeper pans are pretty much the same, look for aluminum ones, I have a TCI one, B&M also has one, and I'm sure theres others.
