4l60 help!!!
Old Jun 13, 2007 | 04:31 PM
speedracer1280's Avatar
Default 4l60 help!!!
this is really long but i wanted it to be detailed..please help
i have a 99 trans am a4...it has 93k miles and has mac mids and a 11" tci break away stall...
just within the last couple of months i put these puts on..what has been happening is the trans whines when in gear. it was fine no whine with the stock tc...few weeks have gone by...yesterday the whine was louder and had a chirping kind've sound...
that and the whine went away this morning... the whole time it has shifted fine and ran great at the track...
On the way home today just leaving the redlight it shimmed a little and then lost all gears...with it idleing checked the fluild, its fine...still pink and does not have to much of a burnt smell...
I turned it off for about five minutes to try again... it then went in gear and i limped home...when i got close and out of traffics way i gave it part throttle and it felt little funny but seemed to shift fine...
once in my apartment grounds i could hear the whineing again..i stopped and put in netrual for few sounds and then in gear and little gas and it moved a little and kindve poped in gear...
does anybody think that the filter could be clogged causeing the pump to whine and line pressure to drop?
please help........
Old Jun 13, 2007 | 04:36 PM
performabuilt's Avatar
LS1Tech Sponsor
The filter is likley clogged but thats not the source but rather the symptom of a problem , You have a trans/converter or both failure in process. Likley both sorry
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 13, 2007 | 07:11 PM
thanks for the quick response...
i just got done changing the filter....its bad....i found shiny metal shavings in the pan... exactly which parts are wearing out....and how much longer do you think it will last? it goes in gear on time and pulls like it should...its gonna need a rebuild...
thanks for the help
Old Jun 13, 2007 | 07:24 PM
PBA's Avatar
PBA
If you have metal shavings in the bottom of the pan, and they do not stick to a magnet, then it is aluminum. The torque converter coming apart can cause this. You have a TCI torque converter, and I have seen them come apart a few times over the years, this might be the cause of this problem. If it is, go with a better TC next time around, such as Vigilante or Yank. I would start saving for a good performance build, as this transmission is history.
Old Jun 13, 2007 | 07:29 PM
LS1Tech Sponsor
Theres no way to know but not to long , let me know if we can be of help many times a built trans is as cheap or cheaper than a rebuilt one local
__________________
Call 888-744-6542
Old Jun 13, 2007 | 08:16 PM
yeah i just checked out your website....the parts in the trans are comparable to anybody elses...but i really liked the 1 year warrantty..my car is making less than 500hp so the pro series maybe the one i go with....not having to worry about a core is also great...
i will get in contact with you possibly in the furture...i got to get some money togther...thanks for the help
Old Jun 13, 2007 | 08:20 PM
LS1Tech Sponsor
Your welcome and ill look forward to it
__________________
Call 888-744-6542
Old Jun 13, 2007 | 09:52 PM
98z28bitcha's Avatar
Damn shawn u broke ur tanny already what u goin to do now.
Old Jun 13, 2007 | 11:02 PM
LS1Tech Sponsor
Call performabuilt lol
__________________
Call 888-744-6542
Old Jun 13, 2007 | 11:18 PM
FLT's Avatar
FLT
Frank you are such a POST *****!
Old Jun 13, 2007 | 11:30 PM
LS1Tech Sponsor
Hey thats my job vince lol help everyone I can and hope I sell something in the process
__________________
Call 888-744-6542
Old Jun 13, 2007 | 11:35 PM
FLT's Avatar
FLT
You need to get a life and stop bumping things TTT with foolish posts. Good night. Vince
Old Jun 14, 2007 | 12:18 AM
LS1Tech Sponsor
This is my life its what I do I help people solve problems and I love doing it good night
__________________
Call 888-744-6542
Old Jun 14, 2007 | 08:32 AM
FLT's Avatar
FLT
please help........
Sorry to be off topic in my posts above that is really a seperate issue. With that being said, I recently did a unit for Matt D and he was having an issue like yours. It turned out that he was having a converter issue as well. His trans was hurt pretty bad due to the filter being filled up with metal from the pump and converter. The clutches and the band were fried due to the lack of fluid pressure. Good luck with your situation. Feel free to contact me if you have any questions. Vince
