How to shift a Auto for Drag?????
if you want to shift it manually, get a manual valve body or a vacuum modulator - both of these turn the 4L60E into a "mechanical" trans - the PCM will no longer shift it for you.
Because if you're at a certain speed, off the throttle, in 4th, and you punch the gas, it takes a second or two for the transmission to kick down and engage the lower gear ratio. In a race, the last thing you want is a delay
With 2.73's, it won't shift to 4th until 168MPH
I don't think a 6,000RPM shift into 4th would be very good at all anyhow.
I used to drag my SS in OD, never had an issue with it. Oh and I modified my shifter with a notch so when I go from 1st to D, it won't pass D unless I press the button.
you may beat your buddy in the race, but his transmission's gonna long outlast yours if you keep doing that.
if you really want to race like that, put the transmission in 1 from a dead stop and drive up to 30 mph. yes, that's still not great for the motor and transmission to be holding the rpms that long, but it's better than what you're doing.
just some friendly advice. no race is worth winning at the expense of your transmission.
