TH400 w/ lockup for a Corvette... Yeah Baby
Old May 8, 2003 | 01:25 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Default TH400 w/ lockup for a Corvette... Yeah Baby
http://www.converter.cc/C-5conversion.htm
The Kit is quite involved and contains the following components:
Bell housing adapter for 4L60E to Turbo 400
Rear differential adapter to Turbo 400
Custom deep Turbo 400 oil pan
Lock-up Turbo 400 conversion, with manual/automatic valve body
Custom gear set with 3.0 first gear
Wide range of torque converter choice to suit racer's needs
Custom shifter brackets, with neutral safety switch (use stock shifter)
Custom front pump
Custom output shaft Turbo 400
PCM tricker box
Full instructions and hardware
Transbrake (optional)
Non-lock-up converters (optional)
Full manual valve body (optional)
