TCI Flexplate
Old Jun 27, 2007 | 03:10 PM
Rebel_Bowtie's Avatar
Default TCI Flexplate
I bought a new flexplate and stall from TCI and now I have a horrible vibration. The TCI Flexplate came with a metal sleeve that fits over the Stall and into the Flexplate. When I tried to install with this bushing my tranny housing was 1/4 inch off the motor, and when I called TCI they said that it was only need if I wan't using a TCI Stall. I've sinced called TCI 3-4 times and each time got different answers as to when this part is needed. I've been told it's needed on all LS1/tranny, only with an LS1/TH350 or 400, only when used with a TCI stall.
Does anyone know what this piece is for?
Old Jun 27, 2007 | 04:14 PM
Gilbert@Ace Racing's Avatar
The pilot hub is different on a th350 and 400 than a 4L60E, that's why they give you the sleeve.
I have experienced incorrect converter bolts causing a vibration, converter is not held tight to flexplate, but you are not talking about a noise, and that is usually noisy after a few hard hits.
Next thing to consider is if the converter is balanced properly. The problems you are experiencing are the reasons why I do not recommend d TCI converters. Been bit way too many times, but that is my own experience. Sorry for no conclusive answer, but hope it helps.
g
Old Jul 2, 2007 | 08:53 PM
pirate3's Avatar
Make sure your flywheel isn't cracked. I just installed a TCI 4200 and a TCI LS1/TH350 flywheel and mine is cracked after 4 passes.
Old Apr 2, 2008 | 08:34 PM
bumpin_records's Avatar
So when is the bushing used that tci give you cause i have one and i will be installing a th400 or powerglide ??
Old Apr 3, 2008 | 02:38 AM
SSilverSSurfer's Avatar
did you grind the face where the bolt holes are? possibly its come loose
