Master cyl, slave cly, or pressure plate.
Old Nov 4, 2002 | 10:43 AM
smokinHawk's Avatar
Default Master cyl, slave cly, or pressure plate.
Ok my clutch is screwwy. When i race or run it hard the clutch will stick to the floor. i have to pull it up with my foot.
I did the drill mod and put high temperature brake fluid in it but it still does it, not quite as bad but still bad.
Any ideas on what the cause is. Is it possible to break the pressure plste?
Or did my master cylinder go bad. or maybe my slave cylider. moneys tight so i need to konw what to fix.
I have a starspec stage # carbon, stock master and slave.
it used to not do it but now it is. i cant get better then a 13.0 on the track, and cant do burnouts. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Nov 4, 2002 | 11:04 AM
cablebandit's Avatar
Default Re: Master cyl, slave cly, or pressure plate.
mine did that with a clutch i had....my ram 402/6130 never did that <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 4, 2002 | 11:48 AM
smokinHawk's Avatar
so you think its the clutch
which one did you have?
Old Nov 4, 2002 | 04:28 PM
MIGHTYMOUSE's Avatar
my old (original version) stage 3 carbon did that after about 14k miles
Old Nov 4, 2002 | 07:21 PM
01Bird_of_Prey's Avatar
I called spec today with the same thing.and thay told me to wrap the line with heatwrap .
Old Nov 5, 2002 | 06:10 AM
smokinHawk's Avatar
that sucks, i realy doubt that wil work. i put high teperature brake fluid in itand the lines arnt new an extreme heat source, how is wrapping the lines going to help?
Old Nov 5, 2002 | 04:37 PM
ahh sounds like an excuse to me. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> c'mon spec just do whats right.. they know that their first gen s3's wear out and overextend themselves after a lot of heat cycles... i sent them mine that did that about 6 months ago.
Old Nov 5, 2002 | 06:13 PM
2FAST4U's Avatar
Sorry about the problem I am looking for a a new clutch I am thinking Mcleod? My car is still at SpeedWorks put Greg will dyno it soon turbos only. Are you going to redyno after your new exhaust. I'll let you now the dyno # when it's done. Oh I was going to ask you how much boost did you get at the end of tuning?
Old Nov 6, 2002 | 05:11 AM
smokinHawk's Avatar
I probably wont redyno till i come back with an ls6 intake, new fuel reg, Subframe connectors (they been ginving my a hard time for not having any.) and fix my clutch problem and wastegate problem. That way they can tweak the tunning, and i'll probably bump the rev limiter up to 7k <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
I was set at 10psi after the tune, with little knock <.97*
I think we can squeeze out another psi or 2 on pump. and id still like to see what shell do on race gas.
